Forums >> General Discussion >> Revit Project Management >> Need help with Family Content
My problem is actually two-fold. One, I have created 6 different families of pipe bollards. I wish to group these under one family (as a content of different sized pipe bollards). I am having a difficult time figuring out how to do this. Secondly, I would rather ike to create only one family of pipe bollards if I could. I have gotten this to work before once, but any time I would choose a different size bollard, only the circle about it's base would change - not it's 3D extrusion, it simply stayed in place. I have tried creating a pipe bollard with parameters established for height and radius. And while the parameter for the height will adjust the 3D model accordingly, the parameter for the radius does not. Like I said, it just creates a different size circle about it's base while the 3D object just stays in place. Can anybody help me with this?
Study & take this family apart and you will see how it works. You need to edit the extrusion to see the locks.
1 Posts No Rating |
I am trying to load in a garage door, and my Revit program will not allow me to insert the garage doors. My hard drive is allowing me to save it into a family, but the program will not allow me to install the door into the floorplan. Any suggestions?
Thank you for your reply WWHub. I had actually done as you mentioned with a similar pipe bollard I had download from this very site. I did not have much luck trying to reverse engineer it to create a family of different sized pipe bollards. As I mentioned before, I got the size of the circle I used to draw it to change each time, but the 3D form itself would not. I did manage to resolve this issue though. What I ended up doing was simply trying another family type. I opened the Structural Steel Columns and modified a simple pipe-column and that worked great! I was also pleasantly surprised that they already had a family of a couple SCH40 steel pipes that we use ourselves for pipe bollards; complete with specifications and wall thicknesses included already. Thanks!
Revit Family Content |
Mon, Jun 3, 2019 at 3:14:21 PM
Revit Users and Content |
Wed, May 11, 2016 at 8:57:38 AM
Content hatch - rotate with component |
Mon, Apr 11, 2011 at 10:22:41 PM
Revit Families - content development - how difficult |
Sun, Sep 25, 2016 at 3:23:11 PM
BIM Content Companies - How May We Help You? |
Sun, Jan 3, 2016 at 10:44:59 AM
Members: | 2114960 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
