52 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Ceiling Plans with Doors showing
7 Posts No Rating |
I'm using Revit Architecture 2008 and having trouble getting the reflected ceiling plans to show how I want them to. I can get doors to show up by changing my cut plane to 7'-0", my trouble is I want to cut through the windows that are above the door and still see the door swing below. I have a strip of windows along an entire wall of offices that are from 7'-0" AFF to the ceiling at 9'-8" AFF. My cut plane should be set to cut through those windows and when I do that I can no longer see my door swings below. Any chance something can be done about this?
![3.5 Stars: 11 Votes](/images/stars_3.5.gif) |
with View / Plan region you can set the cut height lower on a chosen region
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
You can do an overlay of the first floor on a first floor ceiling plan, then you'll need to turn off the stuff you don;t want to see (furniture, fixtures, etc). But you will then have the door swing. Not sure if that is the best way, but it will work. HTH Plan region would require a plan region at every door, though. Also, the plan region would override the window and it would no longer be visible.....
Edited on: Fri, Apr 25, 2008 at 10:10:40 AM
7 Posts No Rating |
Thank you, that's exactly what I needed.
Reflected Ceiling Plans not showing in Electrical Plans |
Wed, May 4, 2011 at 1:19:05 PM
How to load back the Reflected Ceiling Plans into the Project Browser? |
Tue, Jun 8, 2004 at 5:41:39 PM
Ceiling Plans |
Mon, Dec 19, 2011 at 10:20:40 AM
Missing RCP |
Thu, May 16, 2013 at 9:44:04 AM
Floor Plans need to show Ceiling on them in Revit 2011 |
Thu, Aug 26, 2010 at 12:40:35 PM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
