51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2009 subsurface material display
Thu, Apr 24, 2008 at 4:38:23 PM | 2009 subsurface material display
llyons99
We have recently upgraded to 2009 from 2008 and now I cannot change the subsurface material from the toposurface material. I am able to change the toposurface material but the subsurface changes with it. I did not have this problem in 2008. I do get an error when I open that the rendering library is not installed, but I am not rendering this, I am only looking at it as shaded with edges. Is there something we may have missed in the install or does the subsurface act differently in 2009?
Thu, Apr 24, 2008 at 8:07:26 PM | 2009 subsurface material display
LIZARD2806
3.5 Stars: 7 Votes
Does it not allow you to change it in edit mode, as well?  I just did that today, and changed the materail of the subregion when I created the subregion under the "subregion properties" on the menu bar.
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:37 PM
Revit 2009 Additional Material Request
Thu, Aug 7, 2008 at 3:21:23 AM
Revit 2009 Video Display Problems
Thu, Jan 13, 2011 at 1:02:39 PM
Railing material won't show up
Wed, Jan 13, 2010 at 12:20:35 PM
Having trouble creating a material in Revit 2009
Tue, Feb 24, 2009 at 9:41:26 AM
Page generation time: 2.1461
