85 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Combining Sloped and vertical Curtain Wall
Fri, Mar 25, 2005 at 12:51:37 PM | Combining Sloped and vertical Curtain Wall
mharris
I can get Revit make the pieces indiviually but they will not join together and i can't get the mullions to work correctly. Oh and to complicate things more the top plain is arched. Any suggestion? Please see attached jpg.
Mon, Mar 28, 2005 at 9:50:31 PM | RE: Combining Sloped and vertical Curtain Wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the Curtain System tool as opposed to the curtain wall tool. Then either create mcurseto get the faces you want and use the curtain system pick faces option, OR Do a curtain wall by lines and the top and bottom lines for each segment then use curtain system by lines... HTH.
Mon, Mar 28, 2005 at 10:01:44 PM | RE: Combining Sloped and vertical Curtain Wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Here is my quick attempt... Is this what you're after?
Tue, Mar 29, 2005 at 8:58:28 AM | RE: Combining Sloped and vertical Curtain Wall
mharris
which method did you use to achieve this? i used the massing tool and applied the curtain system to the mcurse however, the only way i was able to get the radiused grid line to work was making a separate mcursefor each mcurse the bad thing about that was that when i put mullions on it, it treated each piece of glcurseas an individual curtain wall, and my mullions didn't work properly.
Wed, Jun 15, 2005 at 3:31:52 PM | RE: Combining Sloped and vertical Curtain Wall
RobGoetze
Mr Spot: I'm also very interested in knowing how you created that Curved and Sloped curtain wall.... Please advise on how best to recreate this. Thanks! Rob
Wed, Jun 15, 2005 at 9:07:22 PM | RE: Combining Sloped and vertical Curtain Wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
All i did was create mass to represent the form then used curtain system by faces for the angled walls and curtain system by lines (picked the top curved edge and the lower flat edge) for the arced/radius grids. HTH.
raked curtain wall
Tue, Sep 23, 2008 at 2:09:20 PM
curtain wall door family always vertical?
Thu, Aug 11, 2016 at 7:16:06 AM
Curtain wall on sloped surface
Wed, Jan 7, 2009 at 10:51:56 AM
Curtain wall vertical mullions won't go vertical
Mon, Apr 15, 2013 at 6:19:36 AM
12
Creating a Curved Sloped Curtain Wall
Fri, Jul 9, 2010 at 2:20:03 AM
Page generation time: 3.7512
