94 Users Online (92 Members):
Forums >> Community >> Newbies >> Visibilty Error
Hi I am usinf a hand dryer downlaoded from this website. Problem: I am putting the hand dryer family at level 0 and its working fine. The moment i placed hand dryer at Level 1, its not visible in plan but coming ok in section and elevations. I have tried all the possibilities thru visibility/graphics option.
Now on the implementation stage.... |
Chances are that it is above the cut plane of the plan view. If you want to see it, change the cut plane of the view (View Properties, View Range). If that messes too much with the rest of your plan, you could also do a plan region. The other thing you could do is draw some detail lines and lock them to the hand dryer above (you;d need to do an overlay or temporarily change the cut line). Hope that helps. Cheers.
**Using Revit Architecture 2009, 2011, and 2012** |
sweep visibilty |
Wed, Nov 18, 2009 at 12:51:27 PM
Visibilty Graphics Greyed Out |
Fri, Nov 22, 2013 at 10:42:50 AM
Wall Sweeps in Visibilty Graphics |
Wed, Jan 20, 2010 at 12:10:08 PM
edges color and linetype |
Wed, Apr 20, 2005 at 6:34:22 PM
A Serious Error [ 1 2 ] |
Thu, Jul 26, 2007 at 11:41:07 AM
21
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
