37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> ARGHHHHH....lost file. Found journal txt file though
Tue, Apr 22, 2008 at 8:59:10 AM | ARGHHHHH....lost file. Found journal txt file though
plishe
I've lost a massive file and but have saved incrementally over the night. There are no journal*.rfa files around. I did file a journal1064.txt file from the same time I last saved but don't know how to retrieve the info from it. Any thoughts?
Big Fan
Tue, Apr 22, 2008 at 10:37:22 AM | ARGHHHHH....lost file. Found journal txt file though
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Revit store the journals under c:temp on my my computer, you could try there.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, May 5, 2008 at 5:54:11 PM | ARGHHHHH....lost file. Found journal txt file though
mtyp
You should be able to drop and drag that txt file into Revit and the project will be rebuilt from it.
Mon, May 5, 2008 at 7:07:46 PM | ARGHHHHH....lost file. Found journal txt file though
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
A journal file is no good to you unless the project was created all in one session? Or you can retrieve every journal file for every session the file was edited...  Unlikely.
Hopefully you have some sort of backup system? as if you've deleted the file and its backups then your daily or weekly backup system is going to be your last resort...
Regards,
Chris.
Revit 2012 - Try to recover rvt file from Journal Files
Mon, Jun 25, 2012 at 12:16:27 PM
Execute Journal File through Batch File
Thu, Jun 16, 2011 at 2:33:14 AM
Tue, Jun 14, 2011 at 9:43:14 AM
RST 2010 keyboard shortcuts - TXT file vs Options list
Thu, Feb 11, 2010 at 8:33:17 AM
Excel to comma delimited txt file
Mon, Mar 16, 2009 at 10:57:04 AM
Page generation time: 0.8772
