83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Circular Chain of Reference
Mon, Apr 21, 2008 at 4:23:28 PM | Circular Chain of Reference
mhann
I keep getting an error message that says there is a circular chain of reference among highlighted elements.  I can't seem to get around this.  Any ideas?
Tue, Apr 22, 2008 at 8:40:15 AM | Circular Chain of Reference
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I have seen this and I am pretty sure it means that there is a confilct with some of the constraints/parameters. It sometimes is found in the sketch mode of an object. I usually just try to find out which items are involved in the conflict and by trial and error method I usually can fix the issue.
Wed, Apr 23, 2008 at 12:21:54 AM | Circular Chain of Reference
baek
easy way  around this, in sketch mode, select your sketch line and mirror (with copy unchecked) then mirror at the same axis back to its original position, this will get rid of sketch dimensions and constrains, which you can't see!
Wish List - Kill Circular Chain of references
Thu, Apr 10, 2008 at 1:51:30 PM
Circular Chain Reference
Mon, Aug 14, 2006 at 5:09:53 PM
Error Message: "Circular Chain of Reference" - help requested!
Thu, Nov 24, 2011 at 9:34:08 PM
circular chain refernce
Fri, Jul 21, 2006 at 9:17:19 AM
Circular chain of refenrences (Yes, another one...)
Tue, Jun 21, 2011 at 12:35:49 PM
Page generation time: 4.0042
