132 Users Online (131 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> stairs up & down text cannot be moved
Mon, Apr 21, 2008 at 12:15:46 PM | stairs up & down text cannot be moved
fraz
Hi, Does anyone know why i cant reposition the up/down text in certain views even after selecting it using tab. I was able to move it using smaller-scale display (i.e. 1:1000) though. Is there a more direct way of doing it without changing the scale of my plan? Thanks
Tue, May 6, 2008 at 2:05:05 AM | stairs up & down text cannot be moved
chiragpklg
4 Stars: 11 Votes
Well there's no way u can change the position of the text,  u can just scale them.
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Thu, May 8, 2008 at 6:12:10 AM | stairs up & down text cannot be moved
rahulaklg
or you just can delete the text by unchecking from the stairs properties & create a text of your own choice from the basics.
Thu, May 8, 2008 at 7:19:43 AM | stairs up & down text cannot be moved
Just click on the text - there is a little blue dot in the upper left corner (grip) - hold down your left mouse button over that and drag the text where you want it.
Thu, May 8, 2008 at 7:26:12 AM | stairs up & down text cannot be moved
chiragpklg
4 Stars: 11 Votes
that worked thank's HUB
Chirag C. Pawar
Stairs text
Thu, May 3, 2007 at 9:44:27 AM
Text except up/dn in stairs???
Mon, Feb 16, 2009 at 12:50:15 PM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:16 PM
Copy monitor/coordination review - some elements missing & some not moved
Wed, Jun 24, 2009 at 5:20:20 PM
Copying text & dims from one file to another in 2012
Tue, Nov 25, 2014 at 5:22:35 PM
Page generation time: 1.2276
