108 Users Online (107 Members):
Forums >> Revit Building >> Technical Support >> Section tags visibility on curved wall elevations
10 Posts No Rating |
I have a little complex project with lots of curved walls. I want to show all wall section and building section tags on building elevations. I have realized that it will only show those which are perpendicular to the elevation view. Let me know if you need more explanation of problem. I am using Revit 2008. How can I show the tags? If its ont possible, is there a way around it? Any help?
You can add perpendicular sections in the elevations that "use other view" and hide the call-out for them in the plans.
THANKS It works. I have placed elevation tags in elevation views referencing back to original section views.
viewports & section tags |
Mon, Aug 8, 2005 at 10:20:31 AM
Section Tags missing (again) |
Wed, Aug 26, 2009 at 10:50:38 AM
section tags for broken wall sections |
Fri, Dec 7, 2007 at 10:57:25 AM
dimensioning a curved wall's faces in section? |
Sun, Jan 17, 2016 at 6:59:30 AM
section detail snaps on curved wall |
Thu, Aug 16, 2007 at 3:14:56 PM
Members: | 2042293 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
