54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Border
6 Posts No Rating |
I am trying to create a new border and having trouble with my change order area and date. i would like a field that changes on all my sheets by typing in on one sheet and it carring to the other sheet in the drawing set. Right now i have to type on every sheet the date and change order. any help would be great . Andrew
You need to learn shared parameters. Check out the tutorial links listed in this thread. The same thought process applies to titleblocks. http://www.revitcity.com/forums.php?action=viewthread&thread_id=11078
6 Posts No Rating |
I went through and created shared parameters for the text i want. when i go to add it to my border it will not let me grabe a shared parameter for my boarder. If i add a label to the border i can get the shared parameter but when i loag the border the parameter is in red and i can not type in it. Not sure where i am going wrong..
Did you set the parameter up as a sheet parameter that is "type" based? Should this parameter be a "project parameter"? Check out custom parameters in your help.
trimming vertical mullions to continuous border mullion |
Tue, Aug 13, 2013 at 5:28:05 PM
Patterned Surface border not displaying partially |
Thu, Sep 5, 2013 at 10:01:44 AM
Border Tags |
Thu, Jan 27, 2005 at 12:02:09 PM
White Border Masking Around Annotations |
Thu, Jul 10, 2014 at 1:34:09 PM
Remove border from hatch/ fills |
Thu, Feb 17, 2011 at 4:38:51 PM
Members: | 2022271 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
