19 Users Online (18 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> DETAILS IN SECTION CALLOUT
Sun, Apr 20, 2008 at 4:48:11 PM | DETAILS IN SECTION CALLOUT
jarosa
jarosa Avatar
4 Stars: 5 Votes
Can i get the details (detail lines/detail components/etc) to show up in a callout of a section?
John
Mon, Apr 21, 2008 at 12:45:38 PM | DETAILS IN SECTION CALLOUT
fraz
have you tried "copy to clipboard" then "paste aligned"? if there's plenty of details to be copied, make a window selection then use the filter command to individually check /uncheck items in your selection.
or...if your desired callout scale and section scale are not too different, try "duplicate with detailing" then change the scale and name of the view to "callout of section...".
i hope this helps
Callout Details
Wed, Sep 25, 2013 at 10:31:25 AM
Section callout missing
Mon, Dec 16, 2013 at 4:00:10 PM
can Callout duplicate detailed drawn on section view?
Thu, Oct 4, 2012 at 11:05:03 AM
Callouts/Details
Fri, Jan 25, 2008 at 4:01:12 PM
Using 2d group for Wall section, section details called out from wall section?
Fri, Oct 9, 2015 at 10:50:57 AM
Page generation time: 0.4385
