46 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> apartment areas
Sun, Apr 20, 2008 at 5:27:21 AM | apartment areas
rkarch
1 Stars: 1 Votes
I am using RA2008 - I have finished drawings for eight two storey townhouses and a three storey building which has 22 apartments, with some irregular areas. The floor structures were setup to cover the entrie level, not per unit. Now the client wants a schedule of the size of each of these units. Is there a simple way to do this? It would be nice to even be able to draw an enclosed line around the unit and for the area defined to be then stated....Hope someone can assist.
Sun, Apr 20, 2008 at 2:06:11 PM | apartment areas
blake
3 Stars: 2 Votes
Have you tried an area plan.  Under the room and area tab.  You can then make the boundaries by picking walls or just drawing them yourself.  That will then give you the area of each unit.
Sun, Apr 20, 2008 at 10:31:51 PM | apartment areas
rkarch
1 Stars: 1 Votes
Thank you Blake. I have never used this before and it was quite simple. Appreciate your prompt reply.
Areas for rooms and apartment units
Thu, Sep 7, 2006 at 3:07:39 AM
Using Area Plans as Main Floor and Unit Layout plans
Wed, Jan 13, 2021 at 4:28:16 PM
Wall schedule by apartment unit
Mon, Sep 29, 2008 at 7:14:50 AM
Problem With Linked RVT Files and Associated Levels
Tue, May 29, 2012 at 12:33:34 PM
Shifted Apartment Building
Wed, Jun 22, 2011 at 3:44:04 PM
Page generation time: 0.2145
