Forums >> Revit Building >> Technical Support >> Moving rotate center issues
Is there a shortcut or sth to move the rotate center in current view when we work on bigger objects? Cause it is sometimes bothersome to find it and carry it to the desired place? I use ra 2008
Edited on: Sun, Apr 20, 2008 at 6:34:21 AM
I guess i can announce myself as a nominee of the award for "asker of the most unanswerable questions on Revit" :-D
Edited on: Mon, Apr 21, 2008 at 2:05:13 AM
I don't think there is any shortcut. Click and move is the only way. I wish there was a way to set a Rotation Base point.
in a familie you can draw a big square round your object or whatever and set them to not visible , and the middle off that square will be your rotation point in your project, if thats any help,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thank you guys.
Moving dimension value |
Fri, Jul 17, 2009 at 12:07:35 PM
View Reference center point is too far from the label. |
Wed, Nov 19, 2014 at 9:24:14 AM
Stair Flexibility // Rotate Command |
Sat, Nov 13, 2010 at 7:48:05 AM
Center to center as default for importing |
Fri, Feb 19, 2010 at 11:01:46 AM
ROTATE ELEMENT |
Mon, May 16, 2011 at 8:15:09 AM
Members: | 2100920 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
