61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Modify / remove opening
13 Posts No Rating |
(using Revit Building 9) I cut an opening in a floor. How do I modify my opening, or remove it? If I try to modify the floor, revit is only showing me the original linework of the floor, not the linework of the opening!
if you created the opening using the Opening Tool then the sketch boundary for the opening is independent of that for the floor. see video http://screencast.com/t/c3cdfImqvg
Edited on: Sat, Apr 19, 2008 at 7:33:44 AM
Bump because I can't seem to figure this out 9 years later.
And to clearify, my cut opening is on a sloped roof, created by profile and I can't seem to select the vertical opening cut I created with the vertial opening cut tool/button.
in a 3d view, position mouse on the area or spot in question, then hit tab key cycling through the options.then click and edit.
Modify Window opening |
Thu, Oct 26, 2006 at 6:23:52 PM
help me door and windows pleaseeeeeeeeeeeeeeee |
Tue, Oct 17, 2006 at 10:54:09 AM
Combining two gable roofs |
Tue, Oct 22, 2013 at 8:52:35 AM
roof opening |
Tue, Sep 18, 2007 at 11:45:12 PM
remove web openings from view |
Fri, May 30, 2014 at 3:52:50 PM
Members: | 2030512 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
