41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rotating pattern on flooring
Fri, Apr 18, 2008 at 4:39:35 PM | Rotating pattern on flooring
trhymans
I have created a floor w/ wood flooring finish.  the surface pattern is 3" wide lines for wood strip flooring.  I need to rotate the direction of the pattern 90 degrees and can't seem to figure that out.  I can align the pattern w/ other items parallel but I can only rotate the entire floor and not just the surface pattern.  Anyone help me out on this.
 Thanks
Fri, Apr 18, 2008 at 4:47:20 PM | Rotating pattern on flooring
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Hover over one of the pattern line and tab until you can select it. Then use the rotat command and rotate the line. The rest of the pattern will rotate along with it.
Fri, Apr 18, 2008 at 10:15:09 PM | Rotating pattern on flooring
trhymans
That does it much easier that I finally found a way.  I had horizontal lines that I wanted to make vertical and I made a 45 degree line and then aligned with that and then I was able to align w/ a vertical line.  Not very convenient.
 Thanks for the help
Flooring
Wed, Jun 15, 2005 at 11:22:53 AM
rotating materials
Wed, Dec 26, 2007 at 10:45:41 AM
Floor Pattern Overlaps Furnature
Tue, Nov 30, 2010 at 5:44:58 AM
Flooring patterns
Wed, Mar 28, 2012 at 12:44:10 PM
Ceramic Tile Flooring
Wed, Jan 2, 2008 at 9:03:03 AM
Page generation time: 0.7709
