45 Users Online (44 Members):
Forums >> Revit Building >> Technical Support >> Can't open a Working Project#1
4 Posts No Rating |
I received this message when I attempted to open a revit file: "Element 246673 became corrupt at some time before this session. To continue with this project, save a recover file. In the recovery file, this element will be deleted to fix the problem." Then i received this mesage when i accepetd 2 this mesage ok: An un recoverable error has occured. The programme will now be terminated. All of your data has been recovery saved, so there is no need to create recovery files. How do I open my file to continue with previous? I have followed all instructions what is saying but till now im not able to open my project file. let me know what is the right way 2 open
Did you look for the recovery file ????? You can't open the old file!
5 Posts No Rating |
Audit the file when opening it. I saw this on another thread. I had the same problem and this fixed it. When you open the file there is a check box that says "audit" check it and open the file.
Can't open a Working Project |
Fri, Nov 2, 2007 at 12:37:27 PM
Project won't close |
Mon, Mar 7, 2016 at 12:49:47 PM
Fri, Apr 18, 2008 at 7:21:32 AM
Revit Architecture can't open a large file |
Thu, Feb 6, 2014 at 12:21:01 PM
Can't open REVIT |
Thu, Sep 30, 2010 at 12:48:39 PM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
