42 Users Online (40 Members):
Forums >> Community >> Newbies >> Can't open a Working Project
4 Posts No Rating |
I received this message when I attempted to open a revit file: "Element 246673 became corrupt at some time before this session. To continue with this project, save a recover file. In the recovery file, this element will be deleted to fix the problem." Then i received this mesage when i accepetd 2 this mesage ok: An un recoverable error has occured. The programme will now be terminated. All of your data has been recovery saved, so there is no need to create recovery files. How do I open my file to continue with previous?
Did you do everthing it told you to do? If so, you should see a recovery file that you should now be able to open.
Can't open a Working Project |
Fri, Nov 2, 2007 at 12:37:27 PM
Can't open a Working Project#1 |
Fri, Apr 18, 2008 at 9:56:57 AM
Project won't close |
Mon, Mar 7, 2016 at 12:49:47 PM
Revit Architecture can't open a large file |
Thu, Feb 6, 2014 at 12:21:01 PM
Can't open REVIT |
Thu, Sep 30, 2010 at 12:48:39 PM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
