40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> visibility by level
Fri, Apr 18, 2008 at 3:38:21 AM | visibility by level
HKarlo
 CryingRevit Building 9)
I've got a complex building that is different on each level.
I'd like to have an axonometric view representig each level.
Say, I have level 1, 2, 3, I want an axonometric view that will show me everything that is on level 1, but hide everything that is on the other levels
How do I achieve  this, without having to manually select every object to hide one by one?
Fri, Apr 18, 2008 at 5:53:55 AM | visibility by level
coreed
coreed Avatar
4 Stars: 16 Votes
you can use the section box tool to cut away what you do not want shown.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 18, 2008 at 7:19:00 AM | visibility by level
coreed's suggestion is the best way but remember that you also have worksets available to you.
We like to put our shell on one workset and on large projects, we may put all of the interior items on worksets by level.  This is usefule in some applications because you can then control everything by level through VG.  But this can also be very cumbersome and hard to maintain.
Sat, Apr 19, 2008 at 4:50:01 AM | visibility by level
HKarlo
thank u so much, I wasn't aware of the section box tool yet... it will make everything easier!
Visibility Problem - please help!!!
Fri, Jan 11, 2008 at 10:20:03 AM
Visibility Error
Wed, Apr 30, 2008 at 11:35:43 AM
Visibility of Door Thresholds
Wed, Jul 1, 2009 at 9:50:18 AM
Level Visibility in different Views
Mon, Nov 1, 2010 at 9:26:14 AM
Missing Level symobl on Sections
Tue, Oct 10, 2006 at 1:30:57 PM
Page generation time: 0.4853
