Forums >> Revit Building >> Technical Support >> file getting too big, is there "xref" or something similar?
4 Posts No Rating |
my revit file is starting to get quite large, almost 125mbs at this point. i have already recieved the "memory low, revit may become unstable" message. i dont want the program to crash while im using it. im wondering if there is a way to distribute the file into smaller pieces and therefore make the program run faster. i guess this would be similar to auto cad's xref. where you can only access certain views with certain files, and then there is a ultimate "viewing" file where all the other files are combined. any help would be great, thanks to everybody in advance. please hurry, project due in a week.
May be this tip would be helpful to u or not, but what i do is just divide the model in various files i.e. if I design ground floor in 1 file than the 1st floor is designed in other file, but imp. is to work with grids which will help u to attach all the file together properly.
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
4 Posts No Rating |
'May be this tip would be helpful to u or not, but what i do is just divide the model in various files i.e. if I design ground floor in 1 file than the 1st floor is designed in other file, but imp. is to work with grids which will help u to attach all the file together properly." could you explain the "imp."? nor am i familiar with "grids". how do these 2 things allow me to attach files? thanks again
4 Posts No Rating |
"Xref" in Revit |
Sun, Mar 24, 2019 at 7:52:44 AM
"XREF" Families or other possibilities? |
Fri, Apr 4, 2014 at 1:47:42 AM
Linked Cad File does not show Cad Xref's |
Fri, Sep 10, 2010 at 10:13:51 AM
Opening 2008 file in 2009 causes "Unrecoverable error" crash |
Tue, Jul 28, 2009 at 1:36:34 AM
"File not saved" |
Mon, Nov 26, 2007 at 5:41:47 PM
Members: | 2115367 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
