70 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Cooling Load Calcs
Thu, Apr 17, 2008 at 3:37:39 PM | Cooling Load Calcs
MarauderX
MarauderX Avatar
Revit MEP 2008:
I understand that IES Apache is the load generating software for Revit, and please forgive the newbie questions.
- Can it be used when submitting for LEED energy reduction credits?
- How do I export from IES/Revit to Trane Trace and vice-versa?
- Is there a common how-to and troubleshooting guide here (or anywhere)?
- Can I get more complicated with the mechanical systems used for the load calculations?
- How do I override some of the room information (for example use 0.8 w/sqft for lighting instead of the information from the light fixtures)?
- Can I run a single room, set of rooms, or an entire floor separately?
- How long does the 'trial' version of IES-Apache last?  Should this be permanent instead of just a trial?
Thanks in advance -
~MX
Mon, Apr 21, 2008 at 2:17:10 PM | Cooling Load Calcs
MarauderX
MarauderX Avatar
Bump... someone out there must have a clue...
Sat, Apr 26, 2008 at 5:21:33 PM | Cooling Load Calcs
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
MX-
        I would not fully trust the apache app inside revit for leed energy reduction verification.
       Export the gbxml from your revit model after you have overriden the values (electrical loads, people, etc.)
      Not really, there are other posts out there about this, more on augi.
       Not yet is revit, trace 700 yes.
       Go into the element properties of the selected room, scroll down to energy analysis and click edit for elec. and People, you will then be able to override all values. you must do this for every room you have assigned, this is large problem sometimes when linking an arch model in that has rooms already assigned sometimes all the rooms cannot be copied.
       not in revit 2008, i have heard you can do it in 2009.
         the trial of IES <Virtual Environment> is 30 days. the sustainability toolkit is free for now.
HTH
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Tue, Apr 29, 2008 at 3:24:11 PM | Cooling Load Calcs
MarauderX
MarauderX Avatar
Thanks, and I hope to add more to this as I learn.  I know IES (apache) can be used for generating LEED-complying calcs, but not sure whether having it internally with Revit will yield the same.
Tue, Apr 29, 2008 at 7:29:56 PM | Cooling Load Calcs
twometer
3 Stars: 2 Votes
Revit MEP 2009 took care of some of these problems.  There is now Space instead of room and it is like a room but only used inside of Revit MEP.  This helps separate the architectural info from the MEP info.  Works good so far.
Wed, Apr 30, 2008 at 8:58:05 PM | Cooling Load Calcs
Eddieboarder91
4 Stars: 8 Votes
twometer, gives a valid point. though if you have IES <VE> or can obtain it, i prefer it because you have a little more control over what your in and outputs are. Autodesk and IES have made some very good improvements in 2009.
Thu, May 1, 2008 at 8:21:00 AM | Cooling Load Calcs
MarauderX
MarauderX Avatar
Yeah, it would be nice to control the inputs more closely.
I have the 2009, but the powers that be are holding off on using it for fear of loosing other things.  Kids, what can you do.
I have applied for IES twice now in as many weeks with no reply.  I'm thinking AutoDesk doesn't check their email.
Thu, May 1, 2008 at 10:23:55 AM | Cooling Load Calcs
Eddieboarder91
4 Stars: 8 Votes
If your trying to get 30 trial licences for IES, good luck it took me about 3 months, i just kept plugin away at them. I even called Cambridge, MA, then Europe. But I don't have to do that anymore, since we've become a partner.
Load Calcs for LEED
Thu, Apr 17, 2008 at 3:41:04 PM
Cooling load analysis not registering roof
Tue, Mar 15, 2016 at 11:39:18 PM
Heating Manifold - Supply and Return - Radiant Heating and Cooling
Wed, Nov 10, 2010 at 12:54:49 PM
heating & cooling Report
Tue, Nov 12, 2013 at 4:32:09 PM
Severe cooling problems with rendering with Revit and Max
Wed, Feb 8, 2012 at 12:33:41 PM
Page generation time: 1.3524
