Forums >> Revit Structure >> Technical Support >> SLIGHTLY CROOKED
Thu, Apr 17, 2008 at 7:45:18 AM | SLIGHTLY CROOKED
thankyoufrankgehry
1 Stars: 1 Votes
Hi there all.  I'm working in Revit 9.0.  Every orthagonal line I draw gives me an error message stating that my line is "slightly off axis".  This only happens when I am working on sheets in an elevation view with detail lines.  I am working off a central file and the same occurence is happening on a co-workers file as well.
Thanks,
Aaron
Wed, Jul 16, 2008 at 9:36:07 AM | SLIGHTLY CROOKED
thankyoufrankgehry
1 Stars: 1 Votes
Hi again!  This same problem is  occuring again. UGH! on another job file.  I am still working on REVIT 9.0.  Even if I drag a new level (grid line) accross the elevation (or section) and then try and draw a detail line on the exact same grid line, I get the error message "Line is slightly off axis and may cause inaccuracies".
Does anyone know the cause of this??
Wed, Jul 16, 2008 at 10:26:35 AM | SLIGHTLY CROOKED
thankyoufrankgehry
1 Stars: 1 Votes
I figured it out---my section cut (when zoomed in A LOT@!) was slightly off axix.
thanks.
keynote tag, crooked leader
Tue, Mar 31, 2009 at 4:44:35 PM
placing a family within another
Thu, Apr 8, 2010 at 12:40:07 AM
Problem with Realist view style graphics
Wed, Feb 2, 2011 at 8:14:43 AM
Axis of floor plan are slightly rotated
Thu, Jun 16, 2016 at 5:52:13 AM
Lines slightly off axis
Thu, Nov 9, 2006 at 1:36:13 PM
Page generation time: 0.1909
