Forums >> Revit Building >> Technical Support >> multi pdf printing problem
hi, i'm trying to print 17 sheets to seperate pdf files revit or my pdf writer (cute pdf writer) doesnt do it correctly. A. when i let all the save as windows popup and start clicking save when they are all done it saves the first one and then just doesnt save anymore. ( the windows do go away when i click save ) B. when i click save everytime a save as window pops up there are a few files correct and most of them are corrupt. what is going wrong here?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
When doing multiples with cute PDF writer, you have to name each one differently in the order they are printed. Sometimes that's hard to keep track of because that order may not be as you think it should be. I usually just start at 1,2 etc then open the pdf's and rename them correctly.
dont have time to try that now but i think all the files already had the sheetname in it, so being all unic filenames, but i dl and used pdf995 and that worked fine, kind regards,
peace is the path."
Mahatma Gandhi.
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:47 PM
Printing with Shadows on and PDF |
Wed, Jun 3, 2009 at 1:54:18 PM
problem printing line weight to pdf |
Tue, Sep 30, 2014 at 3:31:50 PM
PDF printing problems |
Tue, Dec 3, 2013 at 7:16:19 AM
PDF Greyscale Problem |
Sun, Nov 29, 2009 at 3:48:22 PM
Members: | 2099093 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
