62 Users Online (60 Members):
Forums >> General Discussion >> Revit Project Management >> setting a central file
42 Posts No Rating |
Hallo, i've been working for some time on a project, and now there will be more people joining to.I am trying to make my current working file central, but the box "make this a central file after save" is not active.I enclose a screenshot.Best regards
![coreed Avatar](user_avatar/14568.jpg)
you have to turn on worksets and enable worksharing before you can make a file a central file. the button will still be grayed out, but it will be checked. this will become a central file whether you like it or not. This process is callled worksharing. there is Revit tutorial on this if you have not done it yet. It may be of help.
Edited on: Thu, Apr 17, 2008 at 7:26:26 AM
thank you i could save a central file without enabling any worksets.just set the desired location folder for a central file in settings/options/general/user paths, and it allow me to select the box "make the file central after saving" I hope there will not be problems after this workaround.
i don't if there will be any problems. there is a certain amount of information that Revit puts in default worksets when worksharing is enabled. whether or not this will be affected i don't know. keep us informed on how things go.
detach from central file |
Wed, May 12, 2010 at 12:28:23 PM
can't save as a central file |
Wed, Sep 9, 2009 at 2:35:47 PM
Opening a File Detached From Central |
Wed, Oct 25, 2006 at 4:06:42 PM
can't view file properties - central path |
Fri, Aug 21, 2009 at 2:34:53 PM
How do i know its a Central File? |
Tue, May 8, 2012 at 8:42:22 AM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
