48 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> Shared parameters
4 Posts No Rating |
I'm trying to create demo tags that would work with a schedule. When I try to create the annotation, the Family editor will not let me choose Shared Parameters. What am I doing wrong?
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
What template are you using...
Depending on what elements you are demolishing, i'd use the multi-category tag so i can tag doors, walls, windows that are demolished all with the same tag.
Then select shared parameters, either browse or create a new shared parameter file. Then create a new group and start adding your shared parameters....
HTH.
4 Posts No Rating |
Thanks Mr. Spot. Will try that.
Shared Parameters |
Thu, Feb 9, 2006 at 1:41:58 PM
Shared or Project Parameters? |
Tue, Jan 19, 2010 at 7:01:11 PM
Project Shared Parameters or Shared Parameters in Families |
Fri, Feb 21, 2014 at 10:22:42 AM
Creating Shared Parameters |
Tue, Nov 25, 2008 at 4:45:08 AM
Shared Parameters File is not a valid... |
Wed, Feb 12, 2014 at 9:31:26 AM
Members: | 2017300 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
