77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Having Dimension text in string, not above dimension string
Tue, Apr 15, 2008 at 10:41:20 AM | Having Dimension text in string, not above dimension string
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
I did some searching and cannot find out how to do this by default.  I can grab the text and move it so it's sitting in the dimension string, but I cannot have it set by default.  In the settings the closest I can get is 0" which is sitting right on top of the line.  Not in it and I cannot set that gap length to a negative number.  Anyone know how I can do this?
Thanks.
Denver, CO
Revit Architecture
Fri, Sep 25, 2009 at 11:30:09 AM | Having Dimension text in string, not above dimension string
Chymos
Sorry to revive an old thread, but I'm having a similar problem.  I do NOT want to use the manual overrides for dimension strings, but would like for the dimension text to appear BELOW the dimension line.  Revit will not let me use a negative value for the text offset.
Ultimately, what I need is a dim string with imperial values above the line, and metric below, but I do not believe that is possible.  Someone prove me wrong...
Fri, Sep 25, 2009 at 11:30:51 AM | Having Dimension text in string, not above dimension string
Chymos
Forgot to mention, using Revit 2009.
Fri, Sep 25, 2009 at 11:44:13 AM | Having Dimension text in string, not above dimension string
http://revitcity.com/forums.php?action=viewthread&thread_id=3324
Now I know you will come back and want to argue but this is your best answer.
Fri, Sep 25, 2009 at 12:18:09 PM | Having Dimension text in string, not above dimension string
Chymos
Pretty much what I have done so far, but I gave one a text offset larger than the other.  This leaves me with a single dimension line with TWO lines of text ABOVE the line.  Not too bad, but ONE line above and ONE line below would be perfect.
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:59 AM
Adding a dimension to a dimension string...
Wed, Jul 10, 2013 at 3:42:10 PM
Removing/editing single dimension in dimension string
Wed, Aug 26, 2009 at 7:12:03 AM
dimension string problem
Thu, Oct 18, 2007 at 1:21:32 AM
Dimension String
Wed, Nov 22, 2006 at 3:05:16 PM
Page generation time: 0.4859
