30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stud wall family help PLEASE....
Mon, Apr 14, 2008 at 4:16:33 PM | Stud wall family help PLEASE....
afsdesign
Please help, I have created a stud wall family but I do not know how I can repeat the stud at 16" centers for the duration of the wall length, any help would be much appreciated.....I am new but learning, I have attached what I have at the moment.....Thank you
Mon, Apr 14, 2008 at 4:18:15 PM | Stud wall family help PLEASE....
afsdesign
I am trying to work on a formula for the reapting of the studs,,,,,, no joy yet as I'm a newbie...... help if you can please.
 Thanks
Wed, Apr 16, 2008 at 7:21:34 AM | Stud wall family help PLEASE....
dianajohn
All you needed to do is use an array
try this out
best of luck John A.
Fri, Apr 18, 2008 at 7:17:39 AM | Stud wall family help PLEASE....
afsdesign
Many Thanks for you input
Mon, May 5, 2008 at 9:45:19 AM | Stud wall family help PLEASE....
Chandej
5 Stars: 2 Votes
Is this what are you looking for?
Tue, May 6, 2008 at 7:12:58 PM | Stud wall family help PLEASE....
Sandoz
1 Stars: 1 Votes
Ok, thats nice.  How did you do it?
Thu, May 8, 2008 at 3:42:05 PM | Stud wall family help PLEASE....
Chandej
5 Stars: 2 Votes
1.  Create doors andwindows family with all studs, headers and all framing.
2.  Create wall using railing.  Verticle studs are balusters and horizon studs are railings, 2-studs at top, 1 stud at bottom and 1 at midpoint, spacing the balusters as you need.
3.  Insert doos and windows on the plan and fill between with stud ( railing).
4.  You should create one stud-railing for corner that end post with 3-studs.
Once you create all families, it should not take more than 1-2 hours to complete you framing.
Create both 2x4 and 2x6 and the height can be any height you want.
Hope this help.
Fri, May 9, 2008 at 9:41:29 AM | Stud wall family help PLEASE....
Sandoz
1 Stars: 1 Votes
If you create a wall using a railing family does that effect the results of a structural analysis?  Or does it?  Revit looks at it as railing not a wall correct?
Fri, May 9, 2008 at 10:28:29 AM | Stud wall family help PLEASE....
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
So do you use an "invisible" wall type to place your windows and doors into?
Brandon Pike | Owner/BIM Specialist
cad.web.print
website: http://www.thinkdesign-studios.com
blog: http://www.bimtionary.blogspot.com/
Fri, May 9, 2008 at 12:36:32 PM | Stud wall family help PLEASE....
Chandej
5 Stars: 2 Votes
This railing wall with 5 1/2" stud will fit inside 6" wall with 5 1/2" structure core with 3/4" plywood exterior finish and 1/2" drywall finish.
You can hide either wall or railing.
Fri, May 9, 2008 at 1:09:59 PM | Stud wall family help PLEASE....
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Oh sure...nifty.
cad.web.print
Family help.... I need to repeat metal studs in my custom wall
Fri, Oct 5, 2012 at 6:53:35 AM
13
Wood Stud wall
Thu, Feb 12, 2009 at 9:05:52 AM
stud wall w brick
Fri, Mar 19, 2010 at 8:45:52 AM
Stud Wall-Make finishes disappear
Fri, Jan 30, 2009 at 5:24:10 PM
Shear studs on Steel Beam Family
Wed, Feb 26, 2025 at 5:57:34 AM
Page generation time: 1.2823
