Forums >> Community >> Newbies >> Hello everyone - newbie here with a simple question
2 Posts No Rating |
HI, i have been asked by my company to explore Revit and one of the questions I had from IT was what is the file size of a typical model. Now I realize that it all depends on how big the model, how many floors etc. but if someone could give me a ballpark idea that would be great. Thanks!
from what i have heared, a good rule of thumb is 5 times x ( a comparable Autocad file size) 1 meg. in Autocad - 5 megs in Revit. how they came up with this ratio i don't know. if it is true or not i don't know. but i'm sure i am about to find out. Which is good, cause i would like to know too.
The first thing to tell your IT guys is that the REVIT file is probably no larger than your combined files from AutoCAD for a similar project. Our working central file for a 4-5 story hotel is about 150 meg at the end of a project but that can be miss-leading to your network guys depending on what they may be looking at. Because you actually work on a local copy and only update items in the main file, I think your network traffic is less than it is with AutoCAD.
2 Posts No Rating |
Thanks guys, that will be helpful.
12 Posts No Rating |
Hi Here are some numbers for reference. Just the architecture plans/model, with no schedules structure or technical stuff. A villa 6500 sq ft on three levels with site contours and exterior walls 5.5 KB A squash court 1650 sq ft; sunken with gym/sauna structure modeled 4.0 KB A barn/studio 2800 sq ft interlocking timber structure modeled in detail 6.7 KB Guy
Revit Rocks |
Newbie Grid Question Revit 2008 |
Tue, May 15, 2007 at 1:48:03 PM
Newbie question about roofs |
Fri, Nov 9, 2007 at 12:31:46 PM
Newbie here...quick siding question |
Sun, Feb 17, 2008 at 3:24:25 AM
Extruded roof - fascia - (Newbie question) |
Wed, Jul 5, 2017 at 8:12:43 PM
13
Very Simple question regarding openings |
Sun, Jan 2, 2011 at 8:18:11 PM
Members: | 2119361 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
