Forums >> Revit Building >> Technical Support >> Walls keep moving
14 Posts No Rating |
I am learning revit 9, and my walls keep moving. the book I learned from didn't give good details of how to get the walls to lock permanetly, I know you can lock components to walls, but can you lock walls to the site? I drew all the exterior walls, but when I move walls inside, the exterior walls move too. I didn't know this was happening, and now my walls are not even close to the original dimensions; is it possible to get walls to never move- not just relations between walls and objects, but never move anywhere- ever
So that is what that pin icon does! I was calling it lock, but Revit calls it pin.
Watch out ! You can over constraint your file and this will cause problems. I usually on pin a few items and I only lock special demensions like for column grid and level dimensions. What I do is use the disjoin button when I want to move something and assure myself that nothing goes with it.
![4 Stars: 11 Votes](/images/stars_4.gif) |
I totally agree with WWWHUB if u lock dimensions & levels, & try movin the objects with disjoin objects it takes care of ur model. Regards, Chirag C. Pawar Cad Solution Application Engineer, +91-9969866851 For KLGSystel Limited, 301, Pujit Plaza, Plot No. 67, Sector 11, CBD Belapur, Navi Mumbai - 4000614, Maharashtra, India. Tel.: +91 22 40916777. Fax.: +91 22 27576461. Mob.: +91 9969866851. Email.: chiragp@klgsystel.com Web.: www.klgsystel.com
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
![3 Stars: 2 Votes](/images/stars_3.gif) |
It sounds like you have your interior walls constrained to your exterior walls without your exterior walls having any constraint to keep them in place. Typically what I do is lock only the main exterior walls to grids or ref. planes, and then dimension and lock those. Locking and pinning everything will slow down and over-constrain your drawing. I tried it once, and it was a bigger headache than having to move and realign everything when the design changed.
moving walls |
Tue, Aug 6, 2013 at 8:54:03 PM
MOVING AND ALIGNING WALLS |
Sat, Mar 10, 2012 at 5:57:39 AM
Walls moving/ disappearing ?! |
Wed, Nov 2, 2011 at 2:37:01 PM
13
Electrical components moving when reloading arch model |
Mon, Jan 5, 2015 at 9:01:02 AM
Walls keep moving |
Wed, Aug 25, 2010 at 5:16:11 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
