Forums >> Revit Building >> Tips & Tricks >> Corner windows
9 Posts No Rating |
Hi im trying to create a corner window. I used one of the corner units I found on here as an example. One side of the window shows up when I insert it into the plan, but one side doesn't. Can anybody help me out? Im attaching the file
![4 Stars: 4 Votes](/images/stars_4.gif) |
Once you have placed your coner window where you want it, you need to go the modelling tab, choose openings->wall opening. Click on the wall which doesn't show the other half of the window. now click beyond where the window could be, then drag the rectangle which is drawn to the corner. Open up an elevation view which looks at the wall where you just placed the opening. Align the opening to the top, bottom, and side of the window.
oh, also, the void that you have on the window which isn't embeded in the wall, get rid of it. Currently Revit doesn't allow us to make corner windows (that I know of) which automatically create openings in both walls, so you have to make an opening. The void won't embed in the wall, so it is just extra information which isn't needed.
9 Posts No Rating |
hmm... ok i'll try that. The window that I used as an example to make my window allowed me to put it into my drawing without having to make an opening in the adjacent wall.
9 Posts No Rating |
this is the window that I tried to follow.
Alright, from what I can see, you came close to what you wanted, but instead of model lines, use symbolic lines. Tell all of your geometry (except the cuts and voids I think) to be visible in elevation only, get rid of floor plan and when cut if family allows. With your symbolic lines, tell them that their visibility is only when instance is cut. I modified your file real quick, granted I just placed symbolic lines over your model lines, and I didn't control any of the visibilty, but it starts to read better in a project.
9 Posts No Rating |
thanks this helps a lot. I had been trying for a while now to get it to work.
Corner windows with variable angle |
Tue, Dec 27, 2016 at 4:47:10 PM
corner windows |
Tue, Jun 3, 2008 at 10:56:06 AM
Corner Windows |
Fri, Sep 11, 2015 at 11:03:10 AM
Corner Windows |
Sun, Feb 25, 2018 at 6:27:00 AM
Corner windows |
Tue, Aug 2, 2005 at 1:51:34 PM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
