58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit in revit linked file
Tue, Apr 8, 2008 at 9:13:41 AM | Revit in revit linked file
Dafpfy
3.5 Stars: 11 Votes
Hi,
i have linked a revit file into an other revit file but now all my text , dimensions,roomtags and doortags do not show?
and in both files the annontiations are set to visible in the view-visiblity property's???
 Kind regards,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Apr 8, 2008 at 10:23:40 PM | Revit in revit linked file
eldados
eldados Avatar
4.5 Stars: 8 Votes
go to Visibility?Graphics and go to the revit links tab, select your link and you can edit how you want your model to display, host view or linked view
also, check that text is not hidden (the little lamp at the bottom)
Integrator
KarelCAD
Wed, Apr 9, 2008 at 2:47:29 AM | Revit in revit linked file
Dafpfy
3.5 Stars: 11 Votes
Hi ,
tnx for your reply, i had to set it to linked view and then set it to the according view.
 tnx again  Smile
peace is the path."
Mahatma Gandhi.
Scheduling from linked Revit file
Tue, Mar 27, 2012 at 7:39:28 AM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:16 PM
Linked File, how can I dimension it?
Sun, Dec 19, 2010 at 8:08:50 PM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:28 PM
Page generation time: 2.4213
