Forums >> Revit Building >> Technical Support >> sweeps and wall styles on sloped walls
I use slope walls in my project. So far it seems i can only open windows in the walls that i create through modelling/create/walls steps, i cannot apply wall styles, cannot place wall sweeps or trim with other walls. So whats the most effective way of modeling slope walls? I am modeling sth like in the attachment.
Edited on: Sun, Apr 6, 2008 at 11:42:51 PM
try using a wall sweep, where the wall starts to slope would be the begining of your sweep. You create this sweep using a profile family, and you can also dictate what material the sweep will be made out of. I've seen these mostly used for chair rails, crown molding etc., but it should work just fine for what you are doing.
Hi all I am proud of myself to achieve the view attached :-) It was not easy but tought me much. I create a sloped wall model (instead of wall sweep as recommended, I guess this is the only way to open a window inside), I used a void extrusion to cut the wall sweeps on side walls. I modelled the window and the framing seperately on left corner window because I couldnt figure out the way to tell framing to go together with slope of) wall. thx
Edited on: Mon, Apr 14, 2008 at 2:23:59 AM
Wall sweeps line weight |
Wed, Apr 30, 2008 at 10:59:06 AM
Walls with automatic wall sweeps |
Fri, Aug 31, 2012 at 3:58:56 AM
Object Styles-Can't find where to change cut lines on sweeps-------------------- |
Mon, Sep 29, 2008 at 4:54:04 PM
Wall Sweeps in Visibilty Graphics |
Wed, Jan 20, 2010 at 12:10:09 PM
wall sweeps won't clean up |
Fri, Jul 11, 2008 at 2:52:47 PM
Members: | 2100424 | Objects: | 23171 | Forum Posts: | 152293 | Job Listings: | 3 |
