52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> 3d views disappearing
Fri, Apr 4, 2008 at 4:37:39 PM | 3d views disappearing
nsbaz
i am having a problem with 3d views all of a sudden being blank. if i create a new 3d view it also shows up blank.
by blank i mean only a white screen with the crop boxes.
i have checked the visisbilty graphics and everything is on, the discipline is set to structural, nothing is hidden.
if i place new structural objects nothing is visible..
any advise/help is greatly appreciated.......
Fri, Apr 4, 2008 at 8:22:32 PM | 3d views disappearing
coreed
coreed Avatar
4 Stars: 16 Votes
go to your 3d view and turn on the crop region
select the crop region
switch to a level such as level 1 and see where the crop region is in relationshipto your model.
here is some addtional info from the Revit Beginners blog by David Durante
Did something in your project disappear?
First, check to see if it is still visible in other views.
Check Visibility/Graphics. Is the object category (and subcategories) ON?
Check Visibility/Graphics. Is the linestyle set to Override?
Check Visibility/Graphics. Is the detail level set to By View?
Check Visibility/Graphics. Are all the worksets ON?
Check Visibility/Graphics. Are all the filters ON?
Check Visibility/Graphics. If the object is in a linked file check Revit Links.
Check Visibility/Graphics. Check each design option.
Try changing phase and phase filter in View Properties (VP).
Try changing the detail level of the view.
Are all your worksets opened? (it may be hiding in a closed workset).
Check View Range in View Properties (VP).
Check for Plan Regions if in a floor plan view.
The object may have been moved to a new elevation.
Check Crop Region and Far Clip settings in View Properties (VP).
Set your view to wireframe. It may be hiding behind a filled region or other object.
Select the Linework tool (set to By Category) and see if it wasn't hidden with this tool. It would be very benefitial if one could toggle on/off the use of the linework tool in a view.
If the problem is with a family file open the family and check the visibility of the elements.
If you can't find it by now it was probably deleted.
HTH
Edited on: Fri, Apr 4, 2008 at 8:23:33 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Apr 7, 2008 at 12:53:36 PM | 3d views disappearing
nsbaz
somehow an object got moved or copied extremely far away from the structure which resulted in a 3d view with objects that are so far away from each other that nothing is visible.
thanks for the response, help is always greatly appreciated..
Disappearing Views in Revit Arch 2008
Thu, Jul 19, 2007 at 12:41:55 PM
disappearing views
Fri, Jul 29, 2005 at 11:19:13 AM
3d and views disappearing
Thu, Aug 24, 2006 at 5:30:40 PM
Disappearing Pipes
Tue, Feb 28, 2012 at 5:00:52 AM
Disappearing Callouts
Thu, Feb 14, 2008 at 11:36:27 AM
Page generation time: 0.4892
