77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> New Curtain Wall Mullion
Fri, Apr 4, 2008 at 4:12:50 PM | New Curtain Wall Mullion
Jbajek
I am creating a new curtain wall and want to make custom mullions.  I have created a mullion profile already, is there something else I have to do first before I can load it into my project?
Thanks
Sat, Apr 5, 2008 at 2:07:03 AM | New Curtain Wall Mullion
dianajohn
Under Families in your browser go to >Curtain Wall Mullions, Select the general shape eg Rectangular, right click select New Type, select the new type & modify it thru its properties renaming it & changing its profile type then use it as you wish.
Hope this helps
Best of Luck John A.
Sat, Apr 5, 2008 at 7:34:49 AM | New Curtain Wall Mullion
coreed
coreed Avatar
4 Stars: 16 Votes
here are some basic steps
Loading the Mullion Family Profile into a Project
1. Click File menu ==> Load From Library ==> Load Family.
2. Navigate to the profile family file you created, select it and click Open.
3. In the Project Browser, expand the Families leaf. Expand the Profiles leaf. The family you created and loaded appears under the Profiles leaf.
Note: if you defined the profile usage, then profile will appear under that leaf.
Profiles for Mullions
You can vary the shape of mullions in a project by loading new profiles for mullions.
Applying the Mullion Profile
1. Select a mullion on the model, or on the Modelling tab of the Design Bar, click Mullion.
2. Click Properties Buttons and go to the type properties for the mullion.
3. For Profile, select a profile from the list.
HTH
Edited on: Sat, Apr 5, 2008 at 7:43:18 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
curtain wall mullions
Thu, Apr 5, 2012 at 1:16:08 AM
Mullion will not load
Tue, Jul 22, 2008 at 8:20:08 AM
curtain wall angled corner mullion
Tue, Nov 28, 2017 at 8:49:21 PM
Curtain wall border Mullion - Profile to align at the centerline
Tue, May 27, 2014 at 9:23:56 AM
Curtain wall corner mullion
Mon, May 15, 2017 at 8:33:53 AM
Page generation time: 1.8664
