107 Users Online (106 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can I replicate the behavior of an dynamic block (autocad) in a revit family?
Thu, Apr 3, 2008 at 6:59:17 AM | Can I replicate the behavior of an dynamic block (autocad) in a revit family?
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
its possible?
thanks
Thu, Apr 3, 2008 at 7:17:05 AM | Can I replicate the behavior of an dynamic block (autocad) in a revit family?
coreed
coreed Avatar
4 Stars: 16 Votes
yes you can replicate quite alot, if not all of that type behavior with Revit families. as with dynamic blocks, its just a matter of knowing what behavior you want.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Apr 3, 2008 at 7:18:26 AM | Can I replicate the behavior of an dynamic block (autocad) in a revit family?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
What is it that you are trying to acomplish? A Revit family is so much more than a dynamic block. Let us know specifically what you are wanting the family to do and I would be glad to help where I can.
Thu, Apr 3, 2008 at 7:41:47 AM | Can I replicate the behavior of an dynamic block (autocad) in a revit family?
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
The Array behavior, I can't find a furmula for it.
For example I have a 2'-0" x 2'-0" windows with 6 louvers and change to 4'-0" x 5'-0" and I still have 6 louvers.
any formula?
Thu, Apr 3, 2008 at 8:01:37 AM | Can I replicate the behavior of an dynamic block (autocad) in a revit family?
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can set up an array and apply a parameter to that array. I would suggest making the louver as a seperate family and nesting it into the main family. You then create the array and define whether you want it to be based on the distance between (2nd) or the total distance (Last). Once the array is set up you can select the object and highlight the array dimension and apply your parameter. Play around with this and when you get stuck you can post again.
Mon, Apr 7, 2008 at 11:58:26 AM | Can I replicate the behavior of an dynamic block (autocad) in a revit family?
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
thanks JAMESHGRIMES I do it my homework on weekend, succeed.
but no so easy as dynamic blocks. I put a parameter in the dimension (label
¹) for louvre quantity and edit manuually.
thanks
¹ this is a very deep hidden command :-)
Fri, Jul 10, 2009 at 10:21:04 AM | Can I replicate the behavior of an dynamic block (autocad) in a revit family?
mahaffey
We have found that the drafting views need to be heavily worked, in order to have a professional looking detail.  Our company has been using dynamic blocks in Autocad 2008.  Now that we are moving into REVIT, I have been tasked with converting all of our blocks to revit components.  We use components that are 2d drafting components to complete the drafting views.  These include the Autocad drawings I have converted from the manufacturer.
 What I am looking for is a method of producing a Drafting component that can be changed without affecting any other placed in the drawing.  Specifically this would be with Curtain wall window jambs, sills and heads.  We would like to imput the width of the component, such as 6 1/2" 8 or 10" and the component would then show at that size.  Currently, we have several components for each.  Is it possible to do this?  If so, how?
Fri, Jul 10, 2009 at 10:35:35 AM | Can I replicate the behavior of an dynamic block (autocad) in a revit family?
This should be a parametric detail family where the depth of the mullion is just a type setting.  One family with a type for each size rquired.  Our mullions are also parametric in the location of the glass and the width of the mullion.
Again ....one family - multiple types.  You could even build a type catalog ... but this only requires 3 so why bother.
Dynamic Weld
Mon, Feb 24, 2014 at 7:24:16 AM
Default how to convert autocad blocks (inserts) into components (family instan
Fri, Nov 9, 2007 at 5:12:51 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
Dynamic Annotations (detail callouts)
Fri, Jul 21, 2017 at 6:11:20 AM
Uin note block
Thu, Dec 3, 2015 at 7:06:54 AM
Page generation time: 4.6803
