82 Users Online (81 Members):
Forums >> General Discussion >> Wishlist >> Lookin for door Group
2 Posts No Rating |
Hello Revity City I am looking for a door group as attached(autocad 2006) to this or if someone can tell me or help me in modifing a door to get this group I would be thankfull (I am not real good at modifing families) P.S. If someone knows where I can get some libary furnture familiy downloads that would be helpfull too. Thanks
![4 Stars: 9 Votes](/images/stars_4.gif) |
The easiest way would be to use curtain walls. Otherwise you have to create a new frame type for each and every instance. The basic steps are open a door family. Adjust the opening size (select the floating line in 3d; hit edit; modify the linework in elevation accordingly). Adjust or add to the frame extrusion. Add the glass. Beyond writting a short novel thats about it. Basically you just need to get in and start playing with the family editor. Work for a while until you get stuck and then post the family on here and ask your questions. There are plenty of people that are willing to help you through issues. There arent many that are willing to do stuff for you though. Work on it and post the family. HTH Nick
Curtain wall model group |
Thu, Jul 21, 2016 at 8:04:07 AM
INSERTED GROUP - COPIED GROUP - DIFFERENT RESULT [ 1 2 ] |
Wed, Nov 23, 2016 at 3:27:29 PM
15
Location or Renaming of 'Door Hardware Group' field in Door Schedules |
Thu, Jan 19, 2012 at 11:06:34 AM
group problem instande not cutting anything |
Mon, Jan 18, 2010 at 9:54:39 AM
edit group panel missing |
Tue, Jan 17, 2012 at 2:54:43 AM
12
Members: | 2017187 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
