Forums >> Revit Building >> Technical Support >> referenced sections
Wed, Apr 2, 2008 at 1:06:05 PM | referenced sections
drawler
I have multiple wall sections being linked from dwg files into drafting views.  Currently the drafting view names are 1/A5-3, 1/A5-4, 1/A5-5, etc.  The problem is that I see the sheet being referenced twice within the section head.  Once on the bottom of the section head from the sheet number label within the rfa, which is correct.  The second is on the top of the section head from the drafting view name.  So for example, I see 1/A5-3 / A5-3.
I can not rename all of the drafting view names to 1 because the names need to be unique.  Often times, the title on a sheet can be different that the view name.  But in this case, I can not seemingly change the detail number within the section head to be different than the drafting view name.  When I right click on the section callout, all of the instance parameters are greyed out.
Please help!  I need a work around for either the drafting view names or for the detail number within the section heads.  Thank you!
"Referenced From" Issue with Section Marks
Mon, Feb 6, 2012 at 2:55:01 PM
Referenced views floating in space
Thu, Oct 22, 2015 at 2:43:48 PM
Sections Referencing the drawing you want. Help Cheat!
Fri, Feb 25, 2011 at 11:22:05 AM
Note with a referenced view
Wed, Jun 29, 2011 at 1:32:52 PM
export dwg with views not referenced
Thu, Apr 29, 2010 at 4:23:32 AM
Page generation time: 0.4790
