74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> How dimension a wall at a 45 degree angle?
Wed, Apr 2, 2008 at 11:28:07 AM | How dimension a wall at a 45 degree angle?
Seewest919
If you notice in the photo there is a fireplace with a 45 degree wall....I am trying to dimension this wall. What is the process for dimensioning this wall?
Wed, Apr 2, 2008 at 11:58:12 AM | How dimension a wall at a 45 degree angle?
3.5 Stars: 395 Votes
Good practice is not to dimension this on the angle - just dimension the x & y...
but if you must, start the dimension command, put your curser at the point you want to dimension from and keep hitting the tab key until you see a tiny dot at that point .... then do the same at the other end.
Tue, Apr 8, 2008 at 9:46:08 AM | How dimension a wall at a 45 degree angle?
JustinT
http://www.revitup.co.za/main/page_tips__tricks_dimension_solutions.html
:o)
angular dimensions more than 180 degree??
Sat, Apr 25, 2009 at 7:09:21 AM
Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
Wed, Sep 30, 2015 at 12:28:52 PM
Cannot make 90 degree angle parametric family
Wed, Apr 11, 2012 at 7:40:02 PM
material image at different angle
Thu, Oct 23, 2014 at 1:19:46 PM
Dimension Question
Wed, Nov 23, 2011 at 11:41:34 AM
Page generation time: 1.1395
