53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Trying to make a template out of a project that had worksharing enabled
![3 Stars: 2 Votes](/images/stars_3.gif) |
All, I am trying to make a template from an existing project. I have srubbed out everything I don't want in the template file and have removed all of the worksets and when I try and save a template it tells me I cannot because worksharing is enabled. Is there a way to work around this to make my template?
Sure ... open the file with detach from central picked. Worksets should no longer be enabled.
I tried that and it still tells me worksharing is active
You could open a new file side by side with this one and transfer the project standards. Won't get you everthing.
10 Posts No Rating |
In the thread above, the dates are jumping back and forth between 2007 and 2006, so I don't know which version you're using, but -- Has this problem been solved in Revit Architecture 2009? Or has a work-around been created? The help would be mucho appreciated! - eye
![3 Stars: 1 Votes](/images/stars_3.gif) |
No, I am having the same issue in 2009. Is there a workaround? I have a project with worksharing enabled, and it wont let me save it as a template.
How to create a template from an existing project that has worksharing enabled? |
Thu, May 28, 2009 at 3:48:18 PM
Worksharing |
Thu, Mar 9, 2006 at 12:29:15 PM
Project Template |
Thu, Oct 28, 2010 at 10:50:06 AM
how to convert a template to project file in 2012 |
Fri, Aug 2, 2013 at 2:58:22 AM
Backup files |
Tue, Dec 23, 2008 at 1:00:27 PM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
