94 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Wood studs
Mon, Mar 31, 2008 at 12:51:43 PM | Wood studs
AlexDring
1 Stars: 1 Votes
Is there a way to show studs in a wood wall?  One of our principles wanted to know how far do we go in terms of coordination with Revit.  Are the engineers responisble for showing every wood stud?
Is there an add on program you can get to input wood framing?
Mon, Mar 31, 2008 at 1:18:05 PM | Wood studs
We would typically never show the stud layout - that's up to the framer.
Mon, Mar 31, 2008 at 2:13:27 PM | Wood studs
AlexDring
1 Stars: 1 Votes
I hear ya, we dont either in Autocad.  We just tell them were we want some bundled studs or post.  The rest of it we let them figure it out.
He was thinking, the boss that is, that with Revit do we or should we?  He is wondering if mechanical and electrical show so much detail like every vent, should we?  Make sense?
Mon, Mar 31, 2008 at 2:25:00 PM | Wood studs
LIZARD2806
3.5 Stars: 7 Votes
We never show wood studs in our architectural plans, and the only time I have seen it done on engineering plans is for a shear wall or modular built homes.  In a past life I worked on a program called Cadwork, which was pretty powerful and not unlike Revit as far as modelling.  In it, you could select a wall and apply a rule (such as 16" O.C., a corner detail and detail at openings) to it, and it would provide you with a stud layout (and cut sheet, to boot).  Pretty cool stuff, but in my experience really only necessary in a prefab sort of environment.  We had used it for making structural insulated panels (SIPs).  I wouldn't worry about showing studs unless their location is absolutely essential to your design. My two cents.
Cheers.
Best solution for wall, floor and roof sub-component listing.
Wed, Mar 5, 2014 at 7:47:27 AM
wood framing wall extension
Tue, Aug 16, 2011 at 4:13:21 PM
Wood Stud wall
Thu, Feb 12, 2009 at 9:05:52 AM
wood framing extension
Mon, May 7, 2012 at 3:23:49 PM
Wood floor way too shiny.
Tue, Dec 14, 2010 at 7:32:40 AM
Page generation time: 0.3473
