Forums >> Revit Building >> Technical Support >> is it possible to add a sky background
35 Posts No Rating |
Hi! I'm completly new to Revit. I have learnt a bit with some tutorials videos. I find it a bit difficult in some ways than autocad and easier in others but what I most like are the 3d views, perspectives and walkthrough. sometimes when I use the camera, I don't get the result I was expecting. this is an example. As you see in the imgage it's all white and in the part of the entrance it's horrible. It would be intresting if at least shows a sky background. Is that possible or waht do you recommend me to do? also, how can "erase" those lines that are from coulumns and the floor (structural things) Thanks a lot!
it is possible to add sky background. have a look at you render setting under environment.
Macca Sunshine Coast QLD Australia |
Yup all under the render settings and environment... you can get Revit to generate the sky and clouds for you, or pick an image to use....this is for Revit 2008 In 2009 the interface is easier as Revit now uses Mental Ray - much much better quality renderings and faster to! You might like to look at this for setting up your lighting.... (if you are on 2008 or earlier) http://www.revitup.co.za/main/page_tips__tricks_lighting.html Justin
Yes ... go to Rendering --> Settings---> Environment --> choose what you want, either the generic type sky using Automatic sky and clouds, or you can choose "background image" and upload a sky jpeg. Good luck : -)
thanks a lot guys! you've been really helpful
How do I get Revit to add sky? |
Sun, Oct 30, 2011 at 6:00:51 AM
RAC 2009 Sky Rendering Problem |
Thu, Jul 10, 2008 at 7:37:36 AM
Rendering Questions re Sky |
Tue, Sep 19, 2006 at 4:34:00 PM
Lost gradient image in background (sky, horizon, ground) |
Wed, Jun 12, 2013 at 3:34:07 PM
No Background Sky |
Sun, Apr 12, 2009 at 3:51:57 PM
Members: | 2102412 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
