24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit ROI >> Options file
Fri, Mar 28, 2008 at 12:47:13 PM | Options file . FILE THAT LET YOU USE LESS LICIENCES!!!
KingRevit
4 Stars: 12 Votes
If you set up the options file right you can get away with a lot less liciences than the number of users. in our office we have 100 fairly heavey users and 20+ plus users who us it for a few minutes a day. We only have 70 liciences and are never short of licences.
If people are interested i will make a tutorial on how to do this.
Edited on: Sat, Mar 29, 2008 at 11:12:38 AM
Sat, Mar 29, 2008 at 9:36:16 AM | Options file
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Sure...shoot for it. It should be an interesting topic.
cad.web.print
Sat, Mar 29, 2008 at 9:44:59 AM | Options file
KingRevit
4 Stars: 12 Votes
i will try to do it today and post it up
Sat, Mar 29, 2008 at 11:00:00 AM | Options file
KingRevit
4 Stars: 12 Votes
Hi,
 So first you set up you Lmtools as normal. making sure your LOG file is working as this is the inly way to tell if the Options file is set up right.
Then in the folder where you .lic file is make a new file called adskflex.opt It has to be named this and you should make the file using Note Pad. Remember not to have it called adskflex.opt.txt , so you have to have your folder structure so that it shows the file extension.
in the options file (.opt) copy the below text between the doted lines , replace all XXX with a name apropriate to your firm.
##XXXXXX-OPTIONS file#Created 10th December 2007###Sets inactivity timeout for all products to 15 mins and Revit 2008 to 15 mins
TIMEOUT 54700REVITS_2008_0F 900
TIMEOUTALL 1800
#Defines report log for use by SAMReport-Lite
REPORTLOG +C:\Program Files\Autodesk Network License Manager\SAMReport-Reports\XXXX.rl
then shut down your Lmtools service and restart it and reread the lic file.
you will know if it is sucsesful if you read the log file in LMTools and it says
-__________________________________________________
 15:41:38 (adskflex) Using options file: "C:\Program Files\Autodesk Network License Manager\License\adskflex.opt"
15:41:38 (adskflex) EXPIRED: 48700VIZ_2006_0F
15:41:38 (adskflex) Server started on stwprinters for: 40100ARCHDESK_3_3F
15:41:38 (adskflex) 48800ACD_2006_0F 455003DSMAX_6_0F 50700REVITS_8_1F
15:41:38 (adskflex) 51200ACD_2007_0F PLIST  533003DSMAX_9_0F
15:41:38 (adskflex) 52500REVITS_9_0F 56900VIZ_2008_0F 54700REVITS_2008_0F
15:41:38 (adskflex) 568003DSMAX_2008_0F
15:41:38 (adskflex) FEATURE   54700REVITS_2008_0F INACTIVITY TIMEOUT set to 900 seconds
15:41:38 (adskflex) ALL FEATURES: INACTIVITY TIMEOUT set to 1800 seconds
Sat, Mar 29, 2008 at 11:00:07 AM | Options file
KingRevit
4 Stars: 12 Votes
Hi,
TIMEOUTALL 1800
if you get a good result like this then if someone has revit open but isn't actively using it after 15 the licience will be returned to the server, don't worry about people who haven't saved there work as when a user returns in say 40 mins the first time they touch revit again they will get the licience back once there are free liciences. if there aren't free licinces then they will be allowed to save there work.
i find this works very well as if your in an office of over 50 revit users i bet that most will have revit open but at any time i bet at least 30% are either sending emails writing reports in meetings our doing someting apart from actually using revit.
any question?
Edited on: Sat, Mar 29, 2008 at 11:11:37 AM
RST 2010 keyboard shortcuts - TXT file vs Options list
Thu, Feb 11, 2010 at 8:33:18 AM
see all design options in one view?
Tue, Aug 28, 2007 at 4:20:37 PM
Design Options Error
Wed, Dec 2, 2015 at 4:41:42 PM
Multiple design options - glitch?
Fri, May 23, 2014 at 9:24:33 AM
Linked Files and Design Options
Thu, Jun 4, 2009 at 4:33:12 PM
Page generation time: 2.9161
