Forums >> Revit Building >> Technical Support >> Exporting Electrical panel schedules to Excel
2 Posts No Rating |
Does anyone know if it is possible to export panel schedules created by Revit to excel format? Thanks, mtrmcemjrsfr
Hello there, If you are merely trying to get a schedule into excel format, you don't need OBDC. All you need to do is got to your schedule. Then go to file>export>schedule. It'll save it as a delimiter text file. Then go to Excel. Go to Data>import external data...>import data. Go find your .txt delimiter text file and you'll get a few dialogs to edit your excel layout. I just leave as default, and click finish. You'll see all your schedule in. Now you'll probably have to edit it a bit as you lose merged cells etc. But a lot easier than typing it out! Hope that helps, Lorne
Denver, CO
Revit Architecture |
2 Posts No Rating |
I tried to do that and in File>Export>Schedule, Schedule was not available, (Grayed out). I had the panel schedule opened but it didn't work. What else do i need to do? Thanks, Mike
hrmmm well that stumps me. I went to my door schedule and it worked fine. I would say just make sure your schedule is the active window and also make sure it's a Revit schedule. Not a legend or drawing view. Make sense?
Denver, CO
22 Posts No Rating |
Exporting is nice, but what is the use of it, if you can't import Excel file back to Revit? Or, maybe I don't know how? I'm trying to link AutoCAD file with linked Excel schedules, it does not work, Revit don't take schedules. Maybe I do something wrong?
" Exporting is nice, but what is the use of it, if you can't import Excel file back to Revit? Or, maybe I don't know how? I'm trying to link AutoCAD file with linked Excel schedules, it does not work, Revit don't take schedules. Maybe I do something wrong? " Well the only use I see, is when you need to send your door/window schedule to say a consultant to edit it and they don't have Revit. I don't know how to import back into Revit, as the schedule is linked to actual model objects so I don't think it's possible (not for sure). As for autocad, I try not to use it. So I can't help you there. Sorry.
Denver, CO
Exporting Multiple schedules to excel at once? |
Wed, May 21, 2008 at 10:11:08 AM
Exporting Schedules into excel format |
Fri, Mar 13, 2015 at 5:53:45 AM
exporting to excel |
Mon, Feb 6, 2012 at 6:26:27 AM
electrical panel schedules in 2011 |
Fri, Oct 22, 2010 at 12:11:23 PM
Electrical Panel Schedules - Space numbers |
Wed, Sep 3, 2014 at 2:49:41 PM
Members: | 2098699 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
