63 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Missing Grid Lines ...again
Fri, Mar 28, 2008 at 9:43:26 AM | Missing Grid Lines ...again
daphnism
I am in the process of working drawings and I have run into an issue with the column line/ level annotations. There are two floor plans which are overall one and enlarged one, (different view of same drawing)All the sudden, all the vertical grid lines are gone in enlarged floor plan, still shown in the overall floor plan. I tried the “maximixe to 3d extent”, it made it show but they got all grid line messed up. So I have to move them back individually. Level annotation seems to have same issue, too. Is there any other solution?Since I am working on huge project, whenever this kind of issue happens, it’s another day to fix them. Any suggestion? Thanks in advance!!!
Fri, Mar 28, 2008 at 10:39:24 AM | Missing Grid Lines ...again
I'm sorry to tell you that this is not a program issue - it's a user issue.  It would be very hard for us to figure out where you went astray - that's something you will have to learn.
You say your plans are different views of the same plan.  If I take your words literally, you need to be careful.  Dependent views are really the same view.
Or did you really mean they are different views of the same level?  Possibly created by copying the view?  In that case, the views can have different settings on everything.  Check VG setting including annotation grids, worksets and even phases if you have messed with those.   Check your hide in view as well (the light bulb)
MISSING GRID LINE IN TWO FLOOR PLANS ONLY
Mon, Feb 23, 2015 at 3:24:54 AM
Column Grid line missing when printing
Mon, Nov 23, 2009 at 11:20:51 AM
Break Grid lines
Sun, Jul 18, 2010 at 9:36:16 AM
grid lines extend beyond detail
Mon, Jul 20, 2009 at 2:06:01 PM
Grid Partial Visibility
Wed, Aug 3, 2016 at 1:08:40 PM
Page generation time: 4.8209
