88 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Turning off one object in all views with one step?
Thu, Mar 27, 2008 at 1:25:44 PM | Turning off one object in all views with one step?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I was just wondering if there was a way to turn off certain objects in all views such as sections, plans, elevations, etc. by just doing one step instead of going view by view turning the objects off in VG (visual graphics)?
 I'm using Revit Architecture 2008.
Thanks!
 LHAA
 Licata Hansen Associates Architecture
Reno, NV USA
Thu, Mar 27, 2008 at 1:40:57 PM | Turning off one object in all views with one step?
TJKENNEDY
3 Stars: 2 Votes
If everything needs to be the same (V/G settings, veiw ranges, everything) you can use view templates. If almost everything needs to be the same, you can apply view templates then go back and change a couple things. The help files do a decent job of explaning the process.
Thu, Mar 27, 2008 at 4:46:08 PM | Turning off one object in all views with one step?
DLicata
DLicata Avatar
3.5 Stars: 7 Votes
I'm sorry is there any other way you could explain that.  I'm not seeing what your talking about in VG (Visual Graphics).
 LHAA
Reno, NV USA
Thu, Mar 27, 2008 at 4:57:00 PM | Turning off one object in all views with one step?
NKramer
4 Stars: 9 Votes
2009 has the ability to pick and chose which parts of a view template are applied. So that would be the best way in the future. Otherwise you are stuck with applying a full view template, setting the "Hide at Scales Corser Than" in element properties, or hiding the object(s) idividually.
Nick
Thu, Mar 27, 2008 at 4:58:50 PM | Turning off one object in all views with one step?
NKramer
4 Stars: 9 Votes
Meaning that you could set up a view template that has the entire section catagory hidden. Its an all or nothing kind of thing.
Along the same lines you could use the "hide at scales corser than" but that affects all views. If you set it to 1/4" then you will never see it on any 18/" plan no matter what...
HTH
Nick
Creating Turning Veins
Tue, Apr 21, 2015 at 6:29:38 PM
Step by Step Guides to Buildings
Sun, Dec 7, 2014 at 7:57:47 AM
turning on/off nested families in host family in different views in project.
Fri, Aug 7, 2009 at 11:11:32 AM
Turning OFF host will enhance preview on Autodesk Seek
Thu, Sep 10, 2015 at 2:08:17 PM
Rotating object using reference line
Wed, Sep 14, 2011 at 4:25:18 AM
Page generation time: 0.5559
