69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Room Name Orientation
Thu, Mar 27, 2008 at 12:27:48 PM | Room Name Orientation
Bomhour
I am working on a plan in revit arch 2008.  the plan has to be oriented with north to the left hand side of the sheet to fit at 1/16" scale.  changing the paper is not an option.  my question is this; why does revit only let you orientate you room names veritcal and horizontal?  it gives no option for vertical left or vertical right.  same thing for the drawing title, does it always put the title at the south side of the drawing?  how do I overide this.
 thanks,
Adam B.
Chicago, IL
Thu, Mar 27, 2008 at 12:33:58 PM | Room Name Orientation
TJKENNEDY
3 Stars: 2 Votes
How are you rotating the plans to make the north side be on the left? There are several ways to do it, and you may not be using the one that will give you your desired results.
Thu, Mar 27, 2008 at 12:56:41 PM | Room Name Orientation
Bomhour
i am using the seting under the view (element properties) Rotate on Sheet 90d counterclockwise.  it also shows up on the sheets layout under (element properties) the same way.
Thu, Mar 27, 2008 at 1:11:28 PM | Room Name Orientation
TJKENNEDY
3 Stars: 2 Votes
I would suggest you use the Plan North/Project North settings. You should rotate the model to the orientation you want on your documents. The use "Rotate True North" to change the direction of true north. Then you don't have to worry about rotating anything on your sheets, everything is already oriented the way it should be. Look through the help documentation and search this forum for project north and plan north, that should help you out quite a bit.
Edit
There is a Cadclip that explains True/Project North fairly well:
 http://www.cadclips.com/downloads/CADCLIP-TRUE-NORTH-PROJECT-NORTH.wmv
Edited on: Thu, Mar 27, 2008 at 1:16:24 PM
Thu, Mar 27, 2008 at 1:18:13 PM | Room Name Orientation
Bomhour
that make more sense.
Thanks for your help.
Adam b.
room areas, room separations
Mon, Jun 2, 2008 at 8:19:43 PM
Room Tag Leader Arrowhead Problem
Thu, Jan 21, 2016 at 11:18:12 AM
3D View orientation won't lock
Sun, Feb 26, 2012 at 7:44:08 PM
add orientation to window schedule
Mon, Feb 3, 2014 at 7:23:50 AM
room tag alignment
Wed, Sep 24, 2008 at 9:38:05 PM
Page generation time: 1.2068
