84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Unable to Change Far Clip Offset
Thu, Mar 27, 2008 at 11:16:51 AM | Unable to Change Far Clip Offset
twhisker
2 Stars: 4 Votes
Here is an interesting dilemma.  The far clip active and offset distance parameters are greyed out on one of our projects exterior building elevations.  When you select the elevation in plan - it shows the offset at 200' - if you slide it, it returns to the same position.  In view properties, the far clip is on but greyed out and so is the distance.
The elevation annotations are in a view that is a dependant view of a parent.  Can this have anyting to do with it?  we tried in both views to change it and it didnt work.  I am not working on this project, and as the firms Revit help desk, I am baffled.  Any ideas??  Thanks.
Revit Architecture 2010
Thu, Mar 27, 2008 at 11:29:22 AM | Unable to Change Far Clip Offset
PeteGGA
The process of making a dependant does grey out the option. Go into the parent elevation actually into the view, then go into view properties and the far clip active should be available to tick, then type in your new distance and it will update your dependant also. it only works in the parent view.
Thu, Mar 27, 2008 at 11:45:54 AM | Unable to Change Far Clip Offset
twhisker
2 Stars: 4 Votes
Thanks Pete - that doesn't work.  In the parent view, both the active check box and the distance are greyed out.  The far clip is already ticked and active - the distance is set to 200'  We would like to change it to 140'.  I also went into the elevation view and it is the same for element properties and view properties.
I think we may just delete the view and see if we can place it again.  Just one of those puzzling ones.  Thanks for your input.
Thu, Mar 27, 2008 at 11:57:10 AM | Unable to Change Far Clip Offset
PeteGGA
I tested it again and it worked for me. one note: when you make a dependant view it creates a elevation marker of the dependant directly on top of the parent elevation marker, if you hover the mouse over the marker and tab once you will select the parent and can drag that although sounds like there is a problem with your project, probably best to delete the dependant, change the distance and create a new dependant
Thu, May 22, 2014 at 1:46:50 PM | Unable to Change Far Clip Offset
lifeinbeats
I know this is an old thread, but I just encountered this problem. If anyone finds this and is still wondering about it, your view template will sometimes control the amount of far clip offset as well as the far clipping type. So if it's grayed out, go into your view template in the same properties box and make sure to uncheck "far clipping."
Fri, Aug 1, 2014 at 10:39:50 AM | Unable to Change Far Clip Offset
RockFish
5 Stars: 2 Votes
I just ran into this on my project and was a bit baffled since there was no view templete assoaciated with the view and the Far Clip Settings were set to Independent.  It might seem like an obvious answer but I guess you should check the Far Clipping to make sure it is not set at No Clip.  I guess you have to set the Far Clipping to clip for you to be able to change the Far Clip Offset...duh.  Just something else for people to check when they come accross this thread in the future trying to figure out this problem (like I did).
Tue, May 26, 2015 at 9:50:21 AM | Unable to Change Far Clip Offset
ajaichohan
I had this problem, and realised that it was because I was trying to change the 'Far Clip Offset' value for the callout's within the section instead of the Parent section -
As soon as I input a value and click enter, the orginal value re-appeared- As i had more then one section line on the floor plan with the same sheet reference I kept going to a referenced view... not the parent. Doh!
FAR CLIP OFFSET - DEFAULT VALUE
Wed, Nov 18, 2009 at 1:26:23 AM
view range top clip plane
Sat, Jan 24, 2009 at 7:56:32 AM
Fleetwood window families unable to offset form exterior
Tue, Oct 18, 2016 at 10:24:43 AM
scope boxes / far clip offset / view range
Wed, Nov 6, 2019 at 2:11:06 AM
Please Help: Seeing wireframe pieces in a hidden line elevation
Fri, Jun 17, 2016 at 11:04:15 AM
Page generation time: 0.7298
