74 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Controlling how stuff deplays beyond bottom cut plane
![MYoung Avatar](user_avatar/18343.jpg)
53 Posts No Rating |
Hi, (Revit 200![Shadey](/images/smiles/shadey.gif) In View Range, I have a typical cut plane at 4' and bottom at 0'. My view depth is set to the level below so that I can see the below info as a reference. Is there a way to control how the objects below the cut plane display? By default they are lighter, but I would like to adjust it if possible.
![3 Stars: 2 Votes](/images/stars_3.gif) |
I am not positive if this is what you are trying to do, but if you go to Settings|Line Styles the top of the list has <beyond> and <hidden> among other things. I am pretty sure those are going to control the objects that are beyond your cut plane.
Right on, I should've picked up on that but I haven't used Revit in about a year. Thanks.
How to control where the cut plane is for families? |
Sun, Nov 22, 2009 at 10:19:59 AM
Linked MEP Ductwork not being cut |
Wed, Feb 13, 2013 at 9:06:06 AM
Cut plane problems with Families - Revit 2013 |
Tue, May 21, 2013 at 2:29:27 PM
bottom view in view range is not active, why? |
Tue, Apr 24, 2012 at 7:22:57 AM
window above cut plane is visible. why? |
Fri, Nov 27, 2009 at 9:25:10 AM
Members: | 2016897 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
