84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to add unit weight as a parameter in rebar schedule?
Wed, Mar 26, 2008 at 2:32:15 PM | How to add unit weight as a parameter in rebar schedule?
rileyking
I can not figure out how to get the unit weight of rebar in my rebar schedule?  I need the units in tons/ft or at least lbs/ft.  Please help...
Thu, Mar 27, 2008 at 10:19:16 PM | How to add unit weight as a parameter in rebar schedule?
dublamby
I am also having this problem. I am new to Revit Structure and have not used schedules to much. I also need to get the weight of columns and beams in my schedules. I see in the properties for the beams and columns it lists the weight per linial foot but I don't know how to get the info into a schedule. Any help is greatly appreciated.
Mon, Nov 10, 2008 at 7:08:33 AM | How to add unit weight as a parameter in rebar schedule?
sujathapadamata
1 Stars: 1 Votes
Hi,
 Please find the excel attatchment for calculating the unit wt of rebar in ton/ Kgs.
Hope it will help you
Thanks
sujatha.p
Thu, Oct 4, 2012 at 6:19:38 AM | How to add unit weight as a parameter in rebar schedule?
nate1hardrada
i'M TRYING TO FIGURE OUT LBS TOO. IS IT LINKED IN MATERIALS? AND HOW DO I YANK OUT A SHARED PARAMETER OUT OF REBAR LINKED TO IT'S  MATERIAL?
REBAR SCHEDULE HELP!!!!!!!!!!!!!!!!!!!!
Thu, Oct 4, 2012 at 6:15:26 AM
Schedules - Grouping by Unit
Tue, Nov 21, 2006 at 5:51:56 PM
Rebar Schedule - Right click to Show rebar in View - I see no "Show... " option
Sat, Nov 22, 2014 at 3:28:12 PM
Rebar Schedule
Thu, Oct 4, 2012 at 6:12:40 AM
Cant add parameter to my door or wall schedule
Thu, Feb 7, 2019 at 10:56:38 AM
Page generation time: 1.1069
