46 Users Online (45 Members):
Forums >> Revit Structure >> Technical Support >> Dimensioning a concrete panel w/ openings in elevation view
3 Posts No Rating |
I know this is do able in plan view, but is there anyway to quickly dimension any openings in a concrete panel in one step? Thanks.
Are you trying to pick on the opening and generate a height & width dimension? Can you not use the temporary dimensions and make them permanent? Pls. elaborate.
Motto: "No Post left behind" |
3 Posts No Rating |
I can select the opening and view dimensions. I was just wondering if I could have them automatically dimensioned since they are associated with the panel. Some panels have more than one opening and would like for these openings to be dimensioned in one step.
Concrete Frame - Elevation View |
Fri, Mar 4, 2011 at 9:28:06 AM
circular openings in concrete walls |
Fri, Jan 11, 2008 at 1:05:05 AM
Can I put a "fake dimension" in my curtain wall infill panel family? |
Thu, Feb 9, 2012 at 2:33:03 PM
Elevation View for Window Schedule Not Dimensioning |
Fri, Sep 12, 2008 at 3:01:09 AM
Wall openings disappear when linked model is turned off |
Wed, Mar 16, 2016 at 1:00:24 PM
Members: | 2017227 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
