50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Elevation Problems
Tue, Mar 25, 2008 at 11:20:47 AM | Elevation Problems
phillpreston
Hi everyone -
Having problems with getting a decent print from Revit Building 8.1 for elevations.  The windows i've put in are the basic family windows, modified w, h and l.  I'm looking for some help on how to tone some of the detail on the windows down a bit so they print with less thick lines.  I'm also looking to add extra mullions to windows that are in the family.   I'd like to make a 3 casement window with mullions splitting the end casements into 1/4s.  If anyone could give me some help with this it would be greatly appreciated.
Cheers!!
www.shewt.co.uk
Wed, Mar 26, 2008 at 1:40:00 PM | Elevation Problems
LIZARD2806
3.5 Stars: 7 Votes
As far as lineweights go, mess with the object styles.  In Object Styles, under windows you will have the choice to change the line weight of the various components.
As for the casement, read through the array function in the help file.  Array works the same way in the family editor.  However, once you make the array.  The muntins should be equally spaced when the width changes if everything is constrained properly. Not sure if that was what you were looking for.
HTH
**Using Revit Architecture 2009, 2011, and 2012**
Revit Strucure 2009 spot elevation problems
Fri, Jul 25, 2008 at 11:48:29 AM
Dependent elevation view problem
Wed, Oct 10, 2007 at 7:44:30 AM
Massing printing problems
Tue, Feb 9, 2010 at 8:11:10 AM
View range in an elevation
Mon, Dec 17, 2012 at 11:27:34 AM
Problems tagging wainscottting wall sweeps
Wed, Jun 20, 2012 at 2:34:37 PM
Page generation time: 1.3371
